71/72/73/74 twin hood scoop factory
badlilred79
badred360
Crossville TN
Rating - 98.3%
57   1   0
got a nice twin scoop factory it has all studs and i cant find any cracks i need 250.00 plus the ride its in crossville tenn 38572
73 Dart sports have a ridge in the middle to form to the hood since it has a raised center and demon ones are flatin the center. The difference is between the snorkels in the front.
I found out the hard way. Try putting a Dart Sport scoop on a Demon hood and you will find that you will have a opening under the front of the scoop. The opening is where the Dart Sport has the peak in the hood. The Demon hood is flat.
i ve got 4 more i'll look to see thedifferent on them and i ve got the cars i have to try them and see .. see your never too old to learn something new thanks.. i'll check the part numbers too
Would you happen to have any that would fit a '70-72 Duster hood with the center rib?
Somebody said that once before on here, about two different scoops, i would like to have the part # for the other one , because any i have ever seen i think end in #357 last numbers but not certain.
