MoparDaddy
Damn Right I Carry!
Lets say I put an e85 setup on a V6. If I were to do that, can I run regular gas in as well or do I have to run strictly e85?
Want to run both, easily, go EFI. e85 requires somewhere in the area of 20% more volume than gas, so the carb needs to be set up accordingly.....
Your car runs on Regular?
Putting E85 on some low compression small block will just cost you money without getting anything in return.
Only if the tbi allows you to change injectors and make the necessary software tweaks. You went tpi with MegaSquirt, FAST etc. might be better off.....Thanks ink! I obviously still have a lot of homework to do, but it sounds like the tbi will be easier to run E85 than a carb
E85 has a different stoichometric air fuel ratio than gasoline's 14.7 to 1 Ratio. The stoichometric air fuel ratio for E85 (at 85% Ethanol) is 9.76 to 1 Ratio.
So you basically need fuel injectors capable of spraying 34 percent more.....
Might want to check out Howell if you are hooked on a tbi.....
Lot cheaper ways to do things if youre on a budget. Power and economy out of a v6, Pirate a turbo oem setup
