70dusterpink
I just got my 67 barracuda.. its my daily driver.. 318/904/4.10
im swapping it over to a A833OD...
I noticed while looking threw all the threads no one has a full write up and swap done from a auto to a manual. some go about halfway and stop...
Im going to document my whole swap here.. I havent even started yet.. but have most of the parts on the way!
The parts needed!
1. The transmission
2. the bell
3. Z bar
4. pedal assembly
5. bar from pedals to z bar
6. bar from z bar to clutch fork
7. clutch fork
8. clutch (comes with TO bearing)
9. shifter
10. linkages
11. floor hump
12. ball stud
13. frame bracket
14. Flywheel
15. yoke (if swapping from a 904)
I beleive that is everything needed to swap over a auto 904 to a manual.. if anyone sees something missing let me know!
OK Lets get started Collecting parts!!!!
I got everything above except for the transmission and clutch all from a member on here... COST $625 shipped waiting on there arrivial..
I am going to look at two A833OD this weekend... one is a cast iron case and the other a aluminum case... will pull inspection cover.. which ever is cleaner i will buy...
I ordered the clutch from autozone... stock replacement $136! it should last behind my mild 318
thats it for now! Any input i will apricate... this is my first auto to manual swap.. on a mopar..
The parts needed!
1. The transmission
2. the bell
3. Z bar
4. pedal assembly
7. clutch fork
9. shifter
10. linkages
11. floor hump
12. ball stud
13. frame bracket
14. Flywheel
