Kelsey Hayes 4 piston Disc brakes
ir3333
ontario,canada
Can you use 10" drum brake ball joints on 4 piston Kelsey Hayes Disc brake spindles?
..do you drill the spindles to 9/16"?
the lower ball joints are different with the disc brakes....uppers the same...
dont know about drilling spindles...
You are asking about Lower ball joints, arent you?
You drill out the mounting bolt holes of the ball joint to 9/16 inch, not the spindle.
oops!
yes i was referring to the lower ball joints from a 10" drum brake spindle.
Tx..
