Throw out bearing and clutch fork
dustya_383
san Jose Ca
hey guys was wondering exactly how the T/O bearing goes on to the clutch fork I have taken 2 pics
Or
I had it like the second one before and when I pulled trans one of the springs on t/o bearing was off
Wondering maybe my fork is too short??
your fork should measure 12 1/2'" overall.
once you install the clutch fork, it should clip on only in one spot. ill take a look at mine and see how it is.
The second pic is correct. Make sure that after fork engages clip inside bell housing, and the linkage end is connected, that you still retain that relationship between bearing and fork. I have seen a lot of screwed up geometry, due to some one changing bell housings , or installing 5 and 6 speeds.
I'm using a Lakewood bell/scattershield
The geometry should be correct if you are using a direct replacement Lakewood Scatter Shield
