[FOR SALE] Complete Magnum top end and fuel injection
93dakman!
carmi
Rating - 0%
0   0   0
I am asking $500 for a of this, or best offer:
This is all off of a 1994 Dodge truck with the 5.9.
Valve covers
Both heads
Intake manifold with fuel rail and Injectors
Distributor
Throttle body
Engine computer
Exhaust manifolds
Complete engine wiring harness
I can t get pictures to upload but if you PM me I will send them through email or phone.
I would trade this entire setup for a set of EQ monster magnum heads with LA intake pattern.
I am in Carmi, Il 62821
I just went out to check the heads and they do not have any cracks between the seats or anywhere else. The intake however is something I didn't even think to look at before. It does have one spot that is blown out and the inside of that pan does indeed have some burnt oil on it. I can replace that gasket for the new owner.
if you do replace the pan for a 1/4" plate and it will never have to be fixed again... just a gasket swap and your lucky to get a month out of it
I don't plan on putting the Hughes plate on it just to sell it. I will however put a new plenum gasket on there. However, find it hard to believe that if you put a new plenum gasket and use an appropriate gasket sealant, whether that be yamabond or just black rtv, that all you would get is 30 days before it blows out again.
