*****Benefit Auction to Help Our Member RustyRatRod*****
I know I'm a little late to the party but I just got home from a trip.
I'll throw in a pair of new 316 precision u-joints. These are the large joint for the 7290 yokes. They do have grease fittings. And I'll start the bid at $10.00 for the pair.
I FORGOT TO ADD ,I'LL PAY THE SHIPPING IF IN THE USA
Let me add a few more offerings to the mix. First up, a set of exhaust manifolds off an '88 Gran Fury 318. They would not fit my Duster with power steering. The left side hit the ps gearbox.
They have been powder coated with a somewhat glossy high heat finish.
The flapper has been removed and JB weld, carriage bolts and lock nuts (without plastic) used to block the holes left.
These have much larger diameters than our stock A Body exhaust manifolds. Maybe they will fit with a manual box?
Shipping on your dime!
C
Next up, a set of used rear shocks from a Duster. I bought them used and did not install them. They seem to be in pretty good shape, the rubber bushings are in good shape with no cracks.
Shipping on your dime.
C
A pair of seat belt parts. They must be from a Duster, either a '72 or '74. Belts look good, but the housing - not so good.
C
Aftermarket A/C condenser. New in the box. It measures 13.5" X 22" overall and the core measures 12.5" x 18.5".
C
New in the box aftermarket a/c unit. Measures 15" wide, 12" front to back and 5.5" tall.
For you boys up north, you probably could plumb this to install heat in your tractor cab for this winter!!!
C
Mostly complete, a couple parts are missing. Brackets and such to mount a sanden a/c compressor on a small block Mopar.
C
Edit, here are pics of the parts. It will easily fit into a large flat rate box, maybe even a medium. To my knowledge the only part missing is a short piece of strap for the rear brace which I used on my car.
Here are additional pics, including the part I used which is shown in the bottom pic.
C
I'll start the bidding on the sanden compressor mount at $10
Will it fit in a flat rate box?
Robs paypal is rlmerritt@windstream.net
SUNDAY, SEPTERMBER 22ND, 2013, 10PM EASTERN/7PM PACIFIC AUCTION WILL BE BROUGHT TO A CLOSE!
1. Blue kick down from Memike(post #1)...High Bidder godfatherofchry $20
2. 360 2bbl kick down from Memike(post #1)...High Bidder godfatherofchry $30
3. Piston keychain from Dart_Doctor(post #13&102)..High Bidder godfatherofchry $30
4. 1949 Plymouth trunk emblem from Memike(post #15)...High Bidder godfatherofchry $10
5. 90 degree oil filter adaptor aluminum from TrailBeast(post #19)...High Bidder hemitheus $35
6. Eddy #1406 - 600 cfm carb from inertia(post # 36)..High Bidder furyus2 $125
7. $50 PSC gift certificate from CudaChick1968(Post #43)..High Bidder daredevil $50
8. '66 Hemi Under Glass 1:25 scale model kit from 63 MorePar5(post #59)..High Bidder Voeltagear $35
9. 426 HEMI fender emblem from 63 MorePar(post #59)..High Bidder WRB426 $45
10. Demon Hat (h3 headwear) from 6pk2goDemon(post #60)...High Bidder 68GTconvert $20
11. Truck tuff wheel adaptor from 72Dart(post #65)..High Bidder YY1 $45
12. Water pump pulley from SB A/C 318. from PanGasket(post #77)..High Bidder kdsmith07 $15
13. 3 Groove SB crank pulley from PanGasket(post #77)..High Bidder godfatherofchry $10
14. Almost new SB starter from PanGasket(post #77)..High Bidder godfatherofchry $10
15. Non A/C SB alt brackets from PanGasket(post #77)..High Bidder kdsmith07 $50
16. Thrush 2.5" muffler from PanGasket(post #77)..High Bidder 75slant6 $15
17. Dodge D100 t-light from PanGasket..High Bidder(post #77) godfatherofchry $20
18. Sony Xplod 6x9 speakers in box from PanGasket(post #77)..High Bidder 75slant6 $15
19. Dodge truck A/C (Compressor, condenser, hoses) from MoparDaddy(post #80)..High Bidder godfatherofchry $10
20. Plymouth Trobleshooting National Finalist patch from YY1(post #82)..High Bidder godfatherofchry $13
21. Custom Visor Mirrors (2) from clhyer (post #114).. High Bidder godfatherofchry $20
22. 1978 Chrysler manuals from Superdart426 (post #113).. High Bidder luckysgarage $30
23. Round back two groove alternator from PanGasket (post #111).. High Bidder godfatherofchry $10
24. Hooker headers for big block Abody from godfatherofchry (post #135).. High Bidder godfatherofchry $400
25. Complete and clean SB rocker arm assemblies for SB from kdsmith07 (post #156).. High Bidder 1970 La $20
26. Good condition driver's side mirror from '72 Duster from kdsmith07 (post #156).. High Bidder kdsmith07 $10
27. NIB 340 Brass Freeze Plugs from kdsmith07 (post #156).. High Bidder 74DartSwinger360 $22
28. Piston keychain PanGasket is giving to RustyRatRod anyway (post #160).. High Bidder PanGasket $25
29. Brand New Big Block Edelbrock Signature Valve Covers from briankaplan (post #163).. High Bidder Old Tired Rebel $35
30. Hot Wheels CoolClassics '63 Chrysler Turbine Car from 75slant6 (post #175).. High Bidder WRB426 $15
31. Straight six piston/rod from(post #184) PanGasket..High Bidder
32. New Dodge emblem for 70 Dart hood(post #187) from 72dart...High Bidder 66340SEDAN $30
33. 1970 Plymouth Duster reproduction owners manual(post #188) from 72dart..High Bidder 75Slant6 $20
34. 7 1/4 shock mounts(post #195) from Voeltagear..High Bidder
35. Black 4 wire ignition box(post #195) from Voeltagear...High Bidder stansnblue72 $10
36. Pair of new 316 precision u-joints from(post #204) SGBARRACUDA...High Bidder daredevil $15
37. Set of exhaust manifolds off an '88 Gran Fury 318(post #208) from clhyer..High Bidder
38. Used duster rear shocks(post #210) from clhyer..High Bidder
40. A pair of seat belt parts. They must be from a Duster, either a '72 or '74(post #211) from clhyer..High Bidder
41. Aftermarket A/C condenser. New in the box.(post #212) from clhyer..High Bidder daredevil $30
42. New in the box aftermarket a/c unit(post #213) from clhyer..High Bidder daredevil $30
43. Brackets and such to mount a sanden a/c compressor on a SBM, mostly complete(post #214) from clhyer..High Bidder daredevil $30
44. '68 barracuda hotwheel(post#215) from johnnycuda..High Bidder
Thanks for your interest. I will pick up a large flat rate box tomorrow and we will find out for sure.
I will also post some additional pics of everything in the box.
C
22. 1978 Chrysler manuals from Superdart426 (post #113).. High Bidder TXDart $25
I'll go $30.00 on the 1978 Chrysler manuals
