dusterdragracer
Drag Racer
1969 Plymouth Valiant
452 C.I. big block Chrysler (440 RB 60 over)
Mopar steel crank
Eagle I beam rods
Ross pistons
12.5 Compression
Mopar performance oil pump
Custom 8 qt pan
Bulldog aluminum heads (Hughes, same as EZ440)
Ultra dyne 620 flat tappet cam
Crane double springs and retainers
1.7 Hughes roller rockers
M1 intake
1050 Holley DP
Runs on 110 race fuel
MSD 6AL ign. With 2 step
Dedenbear digital delay box
Dedenbear shift by time
Shiftnoid electric shifter
B&M pro Bandit shifter
Barry Grant 400 fuel pump
10 gal Fuel cel
2 new Optima batts in trunk
Auto meter gauges
TTI 2” coated headers
3 ½” race mufflers
JW ultra bell complete ‘Glide
JW 8” 5500 converter
JW transbrake
JW “the wheel” flex plate
9” ford diff. (new 1 season)
Yukon Nodular case
Richmond 4:57 gears
Daytona bearing support
35 spline Moser axels
1320 joints w/billet yoke
11” Ford drums rear
Large pattern front disc
Complete Cal Trac system (new 1 season)
Rancho front shocks
Rancho 9 way adj. Rear shocks
Mono Leafs moved in-board (mini tubbed)
Cal Trac Bars
6 cyl. Front T Bars
Full cage, would cert. to 8:50
Solid front mounts
Mid plate
Poly trans mount
All new Weld wheels and tires
Hoosier 29 X 11.5 W (13 ½”w) X 15”
Rear Hoosiers have another season left
Aluminum cross flow Rad.
Electric pump
Electric fan
Mopar Alt.
This car is super reliable, never runs hot
The way it is wired, everything is automatic
You never touch a switch
Super stable and easy to drive
Last year at Summit series as new car, won a race, runner upped a race
Finished # 5 in points S/Pro
This year Summit won a race; runner upped a race. Finished # 3 in points in S/Pro
Everything on the car is new, or near new. Everything is fresh, needs nothing but new seat belt in the spring
Great paint (decals are removeable)
All new carpet
2 front seats
All steel except hood & bumpers
All glass windows roll up
All lights work
Starts with key
Weights 3079# without driver
Has vin on dash
No title
Sold with Bill of Sale
Could be made to street car easy
Runs 10:70’s @ 121 MPH @ sea level, runs 11:07 @ 120 MPH @ 5000’ easy pass, shift @ 6200
Link to more pics:
https://www.facebook.com/media/set/?set=a.1818250462323.2090885.1421974018&type=1&l=1ff4e99ce7
$15,000.00 O.B.O.
No Trades Thank you
Please NOTE
PM offers or questions
With all due respect, please don't post your comments or opinion about my listing, if you have a comment about the car, PM me personally
Thanks Chris
Mopar steel crank
Eagle I beam rods
Ross pistons
12.5 Compression
Custom 8 qt pan
M1 intake
1050 Holley DP
10 gal Fuel cel
Auto meter gauges
3 ½” race mufflers
JW transbrake
Yukon Nodular case
Richmond 4:57 gears
11” Ford drums rear
Rancho front shocks
Cal Trac Bars
6 cyl. Front T Bars
Solid front mounts
Mid plate
Poly trans mount
Electric pump
Electric fan
Mopar Alt.
All new carpet
2 front seats
All lights work
Starts with key
Has vin on dash
No title
Link to more pics:
$15,000.00 O.B.O.
No Trades Thank you
Please NOTE
Thanks Chris
