crane ductile rocker on Indy x heads???
moparracer54
Active Member
O'Neill Nebraska
Just wondering if anybody has used these on these heads and how the geometry is??? Thinking about getting a set of 1.6's because the prw ones I got are junk. My rules specify steel rockers only so my options are very limited.
Have you thought about shimming the rocker arm to help Geometry?
Probably the only option you have, and closer to actual advertised ratio than factory.
Run'em.
Dead on.And the only way to find out proper geometry: Do a mockup. Having the whole build up would help immensely. The iron rockers,clear most everything.
