1971 Match Race ~ 'Duster 340' vs. 'Boss 351 Mustang'
69 Cuda 440
Legandary Member
Legendary Member
Wilton, Connecticut
1971 Match Race
'Duster 340'
vs.
'Boss 351 Mustang'
1971 'Duster 340' 4-Speed
Shipping Weight..... #3165 lbs.
Curb Weight........... #3340 lbs.
th
Both bone stock with same gears I think it would be a good race with the Mustang beating the Duster... Man that was hard to type!!!!!!!
Specifications
Engine 351.9-cu-in/5766cc OHV V-8, 1x4-bbl Autolite carburetor
Power and torque (SAE gross)
330 hp @ 5400 rpm, 370 lb-ft @ 4000 rpm
Drivetrain 4-speed manual, RWD
Brakes front: solid disc; rear: drum
Suspension front: control arms, coil springs, anti-roll bar; rear: live axle, leaf springs
Dimensions L: 189.5 in, Width: 74.1 in, H: 50.1 in
Weight 3452 lb
Performance 0-60 mph: 5.8 sec, quarter mile: 13.8 sec @ 104 mph, 60-0 mph: 116.5 ft (Motor Trend, January 1971)
Price when new $4101
I think this boss 351 was the only small block that made it into the fastest 50
Muscle cars.
This is close. little Duster flys.
[ame="http://www.youtube.com/watch?v=EJdEWIbfR0Y"]1970 Duster vs 1970 Torino Cobra - YouTube[/ame]
I know the Boss 302 could not run with the 340 swinger.In 1970 had 2 guys with both the swinger always came out on top.Kevin.
Only gear that was offered was a 3.91.
Special spread bore carb $$$$$$$$$$
It really was a very special engine!!
At the heart of the Boss's heavily massaged 351 Cleveland was a crankshaft cast of high nodular iron, specially tested for hardness, and held in place by four-bolt mains. Connecting rods were forged, shot-peened for strength and magnafluxed for cracks, and held to the crank by exceptionally strong 3/8-inch bolts. At the other end of the connecting rods were eight pop-up, forged aluminum pistons with three rings apiece. The free-flowing 4V heads were nearly identical to those used on the earlier Boss 302, except for their revised cooling passages. Generous, smoothly contoured intake passages led to the large, canted valves--2.19 inches for the intakes, 1.71 inches for the exhausts--helping the engine breathe freely, allowing "excellent performance potential," as the brochure said. The polyangular combustion chambers created a relatively high compression ratio of a high 11.7:1. Hardened and ground pushrods, solid lifters and special valve springs and keepers beefed up the valvetrain. Like other members of the Cleveland family, the HO 351 had a bore and stroke of 4.00 inches x 3.50 inches.
A cast aluminum over/under intake manifold was capped with a 4-bbl. Autolite model 4300-D carburetor with a spread bore pattern with small primary bores and oversized secondaries. These carburetors were built just for the Boss 351 engine, and are "extremely rare," according to Prochot. "If you can find one, it's probably going to cost you upwards of $3,000 for an unrestored one," said Carol Jennings, business manager for Pony Carburetors, a Las Cruces, New Mexico supplier of carburetors, carburetor parts and restoration services. "And you're probably going to be waiting a long time." The 4300-D draws breath through the Dual Ram Induction hood with its vacuum-actuated ducts. A dual-point, dual-diaphragm distributor fired the Autolite ARF 42 plugs, and cast, finned aluminum covers with special Boss 351 insignias sat over the rocker arms. Ford advised that buyers who wanted an oil cooler could adapt the oil cooler from a 1970 Boss 302; none were installed on the HO 351 at the factory.
Specifications
1971 'Duster 340'......................................................................1971 Mustang 'Boss 351'
Shipping Weight.......... #3165 lbs............................................. #3281 lbs.
Curb Weight................ #3340 lbs............................................. #3430 lbs.
340__________________________________________-____351
Bore..........4.04"....................................................................... 4.00"
Stroke...... 3.31"....................................................................... 3.50"
275 HP 'Factory Rated'............................................................. 330 HP 'Factory Rated'
275 HP @ 5000 RPM's.............................................................. 330 HP @ 5400 RPM's
340 Ft/Lbs. of Torque @ 3200 RPM's....................................... 370 Ft/Lbs. of Torque @ 4000 RPM's
Red Line................ 5850 RPM's............................................... 6150 RPM's
{ 310 HP 'NHRA' Rated }......................................................... { 330 HP 'NHRA' Rated }
1971 NHRA Class... G/S or SS/I............................................... F/S or SS/I
Compression........ 10.3 to 1..................................................... 11.3 to 1
Piston................... Flat-Top w/2 Notches................................ .315" Dome
Type..................... Forged Aluminum....................................... Forged Aluminum
Piston Height....... +.045 'Above Deck'..................................... -.008" 'Below Deck'
Crankshaft.......... Forged Steel................................................. Cast High-Strength Nodular
Rods................... Forged.......................................................... Forged ~ Shot-Peened and Magna-fluxed
Piston Pins......... Full-Floating.................................................. Pressed-Fit
Rod Bolts............ 3/8".............................................................. 3/8" ~ Special Length and Hardened
Cylinder Head...... #3418915 'J' Head...................................... D1ZE-B
CC Chamber......... 71 to 73 {Factory}...................................... 67.6 {Factory}
CC Minimum........ 63.3 CC {NHRA}.......................................... 64.6 CC {NHRA}
Intake................. 2.02"............................................................ 2.19"
Exhaust............... 1.60"............................................................ 1.71"
Intake Volume.... 149 CC.......................................................... 244 CC
Exhaust Volume.. 69 CC............................................................ 136 CC
Camshaft............ 'Hydraulic'..................................................... 'Mechanical'
Lift...................... .463"/.472" {NHRA specifications}.............. .491" / .491" {NHRA Specifications}
Duration.............. 276*/284*................................................... 290* / 290*
Overlap............... 52*............................................................... 58*
Valve Springs...... #134 lbs. 'Closed'......................................... #93 lbs. 'Closed'
Valve Springs.......#235 lbs. 'Open'........................................... #315 lbs. 'Open'
Rocker Arms........ Stamped-Steel Non-Adjustable.................... Stamped Steel 'High-Strength' Adjustable
Intake................. Cast Iron 360* Dual-Plane High-Rise........... Cast Aluminum Dual-Plane High Rise
Carburetor.......... Carter Thermo-Quad {800 CFM}.................... Autolite #4300-D {750 CFM}
Throttle Bore...... 1.375" Primary ~ 2.250" Secondary............... 1.563" Primary ~ 1.690" Secondary
Distributor......... Dual-Point....................................................... Dual-Point
Air Cleaner........ Unsilenced....................................................... Ram-Air Induction w/Twin 'NASA' Hood Ducts
Exhaust Pipe...... 2.25"
Transmission..... 2.44 / 1.77 / 1.34 / 1.00 {A-833}.................. 2.32 / 1.69 / 1.29 / 1.00 {Close-Ratio}
Clutch................ 10.5".............................................................. 11.0"
Spring-Load.............................................................................. #1845 lbs.
Flywheel................................................................................... 27.3 lbs.
Shifter............... Hurst Linkage.................................................. Hurst Shifter
Gears................ 3.91 'Sure-Grip' {Optional}.............................. 3.91 'Traction-Loc'
Rims................. 14" x 5.5"......................................................... 15" x 7"
Tires................. E-70 x 14" Goodyear Polyglas GT...................... E-60 x 15" Goodyear Polyglas GT
I stuck a 351C from a '72 Cougar into my '68 Mustang coupe.
It wasn't that fast.
....because it just smoked the L60s on the back like they weren't even there. Including at about 70 on the highway lol.
I could never figure out why the boss 351 did not kick butt in pro/stock after they adjusted rules for small blocks.Kevin.
Actually it did. Bob Glidden did pretty well with Clevelands.
1971 'Duster 340'
4-Speed w/3.91 'Sure-Grip'
Rapid Transit Magazine Test.............. 14.04 @ 99.2 MPH
Now, if you knew someone at the 'Regional Zone Office' you could finagle
a 1971 'Duster 340' with,
* A Factory Calibrated 'Race-Ready' Thermo-Quad Carburetor rated at 850 CFM
* A 'Special' Heavy-Duty Clutch Package
* 4.10 Gears
Of course, this was not advertised.
Rapid transit testing.. Funny... Just like this drag racing test of the boss.. Ringer??
4) Drag Racing February 1971
“Best et during initial testing was 13.24, making 12’s easy with proper attention to tuning, chassis, & tires & putting 11’s within reach”. Pg 21
13.24 "out of the box"
I do believe the Boss 351 was alittle quicker. The best 71 Duster test I have seen is in a Oct. 1971 Speed and Supercar. It ran a 13.90
The 'sound'..................
1971 'Unsilenced' Air-Cleaner
1971 'Duster 340' ~ 4-Speed ~ 3.91 'Sure-Grip'
Magazine Performance Results
* 13.90 @ 100.99 MPH
* 13.98 @ 100.33 MPH
* 14.01 @ 100.14 MPH
* 14.04 @ 99.20 MPH
* 14.07 @ 100.09 MPH
* 14.11 @ 99.87 MPH
Glidden made them run by cutting part of the head away from the exhaust side & installed his own section in.
He didn't do it with stock cleavland heads.
Early Performance Tests,
1971 'Boss 351'
* 14.09 @ 102.78 MPH........{w/Rev-Limiter set @ 6000 RPM's}
* 13.80 @ 104.82 MPH........{Shifting @ 6500 RPM's}
While I have never owned a 340 . I have had 3 Boss 351s and they were a blast when you were pushing them hard . However due to the large valves and massive intake runners the cylinder heads were better suited to racing than being used as a DD . If I remember correctly the Boss 351 was developed so it could be used in Nascar. If I had a Boss 351 today I would be shelving the Boss heads and replacing them with a set of Aussie cleveland heads .
* 14.01 @ 100.14 MPG
* 14.04 @ 99.20 MPH
* 14.11 @ 99.87 MPH
Could you post the actual magazine write up on the two 13 sec pass ones?
