1974PlymouthDuster
Hi guys - everyone has been able to throw in their $0.02 about the 70 Valiant sedan project. Appreciate all the input. A little more rust than I'd hoped for, but just a little Slant 6 Sedan for me to plow around town in.
Main driveability issue I have is a hole in the gas tank, presumably from rust and/or age, I can't fill it up past 1/4 tank, or it leaks from a high spot.
Already confirmed it's not the sender or gasket.
With such a critical item (gas), I decided to throw in a couple bucks for the tank project.
Purchased the decently reviewed Spectre gas tank from amazon. Full list of purchased items:
Gas Tank (includes lock ring)
squeek pad to cover on top of the gas tank, between body.
felt straps for strap squeeking
two new strap bolts (the bent L-ones)
two new metal straps
two oetiker hose clamps
Re-use old sender - it works, but going to give it a good cleaning.
I have tried to go through all resources to review the project piece by piece, and hoped to source all parts to do the job correctly.
My question for the crew is
#1 - Anything you wished someone told you before you did your first tank?
#2 - Any parts I'm missing?
Only item I need to find (I think?) is the filler grommet
http://www.classicindustries.com/mopar/parts/mf296.html
