Harness ID ???
pilotsf
I have a 68 dodge dart that had old pints and single field regulator and slant 6
I put 360, went to MP ignition and wired a new style regulator. All that splicing... Tried to use revenator box and I've got wiring issues.
Classic industries has modified wire harness for the upgrade all ready.
What are the 3 harnesses.
I know the right is wiper. Wat is the middle and left. I need to order the right ones. Please help.
Posted via Topify using iPhone/iPad
What do you mean, you are going to replace the underhood harnesses??
Have you downloaded a shop manual yet?
http://www.forabodiesonly.com/mopar/showthread.php?p=1970088617
http://www.mymopar.com/index.php?pid=31
68 service manual from MyMopar:
http://www.mymopar.com/downloads/servicemanuals/1968_Plymouth_Service_Manual.zip
Now, you have to use you head. Look at the diagram for the engine compartment, which in the above manual is on page 334 in your viewer, page 8-108. the diagram of the bulkhead connector. The individual connectors on the page which fit the bulkhead connector are looking INTO the connector, and the bulhead connector is looking at the bulkhead connector as it sits on the firewall
Now all the wiring for the lighting wiring is not shown on that diagram. But the top connector, which fits the left side, is the "lighting" section. The second one down (middle) is the "ignition" harness" and the last one down to the right, is your "wiper" harness
Wow. This is awesome !!! I have the diagram but you broke it down perfectly. Yeah. I'm only wanting to change the ignition harness. The one for the regulator alternator and ignition box and so on. So from what I gather it's the middle one. Thank you very much !!! I'm just trying to get a cleaner and better wire set up for better ignition after years of splicing. Now I just hope classic industries has the one I need.
Thank you.
* side question. If I get a new 70 dart harness with the my motor configuration in theory it should work right. The plugs and connectors will be updated for all my needs. But will have the same fire wall plug ?
Dale.
New it is offered as both the engine/ lighting harness together for a-body from CI or YO. I have bought several of them for under 200 it is hard to go wrong.
Right on. I just ordered it. What crazy is the 1968 dart one is only 112$ but the 67 and 69 was 189$. YO and CI both didn't know why it's cheaper. Hopefully I got the right one. Thank you !!!
