Dustin The PcP
So it' been a while since i've been on, but started working on the car again so of course money is low. So that means time to get rid of some old/not used parts! Also I do not currently have access to a camera but can get you pictures if asked just pm me. I will try to upload some when I can to here as well.
Stock replacement 318 Rods and pistons with rings installed less than 5,000 miles on them. They are .040" over pistons Asking $300
Edelbrock performer RPM cam springs and lifters Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 308/318, Lift .488/.510 This cam has been broken properly and has no wear with less than 1,000 miles on it. I do still have the lifters matched to the specific lobe they were sitting on. Asking $250.00
Stock 318 oil pump with less than 5,000 miles on it asking $20
Double roller timing chain for 318 less than 5,000 miles on it Asking $35
8 3/4 Rear end for A-bodies with high gears (2.73-2.9X) 5X4" bolt pattern it is an open rear with stock sping locations and has no drums or brake cables Asking $375
Stock 318 1974 torsion bars Asking $35 for the pair
Stock 318 rocker arms 1.5 ratio has rails and all hold down gear asking $150
To the miscellaneous parts now we will start with
1" greasable polyurethane sway bar bushing new in box Asking $15
2003 Dodge ram 1500 4.7 throttle body new in box Asking $125
1 ford brake caliper I believe to be off a 2008 f-150, it is dual piston and I am still looking for details on part number it has a AL3z2b120 on it, trying to figure it out, any questions ask I will try to answer. It is New in Box I believe it is a ford part I will double check Asking $75
2 ford brake lines caliper to body mount Also believed to be for a 2008 f-150 once again still looking in on details Asking $25 a piece or $40 together
All shipping is from Sugar Land Texas 77498
