twayne24365
How do you measure block deck height. Center of main journal to deck, also what tool do you use?
what do you think a shop would charge?
Its not just a simple crank CL to deck- you also have to correct the crank/cam CL to deck angles- 45 from Crank/Cam CL and 90 to each other, along with parallel to the mains. It requires a special fixture or a CNC with indexer, not just a surfacing machine. You need a point of reference other than the OEM decks that are far from accurate. You need to line hone the mains first to really do it right.
Going off the 4 corners only tells part of the story and is still a matter of tolerance stack.
I make sure the crank rod journals have been equal stroked and indexed. then with the crank/main brgs in the block I install the same piston/rod combo at all four corner cylinders. Install piston w/o rings or some like to have the oil ring installed to add a little drag to the piston so it wont slide up/down too easily as you find tdc. Using magnetic dial indicator I find exact tdc of piston in each cylinder, then measure the distance piston is down the bore from deck surface. Like Rusty said the four measurements probably wont be the same. then have shop machine the block decks so they are parallel with crank centerline. after machine work I mockup the crank/piston again to verify all four corners have the same measurement...or at least real close.
Is that the BHJ Block-Tru you're using there?
Ted
We get all that, but "I" was trying to keep it simple for the sake of conversation.
