340doc
I have a red top in the trunk, seems like its getting weak. About two, two and a half years old.
AGM batteries like Optima's will require periodic "deep" slow charging to maintain long life. The proper info can be found on the Optima web site.
Yeah, I went over all the connections, the only thing I found was the small bolts that attach the field terminals to the alt were loose. The resting voltage of battery is 12.2 , with car running 14.6The ones with the batteries in the trunk that have been there for awhile might want to make sure of the terminals and connections before assuming it's the battery.
Not saying tha's what it is, just that it could be.
My red top Optima is going on atleast 15 years old and going strong....it was still made in the USA, Colorado I believe and is the best friken battery I ever had, used it in 2 cars now and never an issue, even charge it with a regular charger and has been run dead many times when a few alternators went out or something drained it......wish I had bought more at the time I got this, heard the new ones are junk.
Mine is 9 years old and still going strong. I do disconnect the positive when the car is sitting. And yes they do like a slow low amp charge every now and then.
