[SOLD] 68 Barracuda firewall and cowl, rt inner fender, front frame rails
ragtopfury
Manchester, MD
Very solid firewall and cowl that is part of the remains of a 68 Barracuda. No rust thru on it. Still needs to be cut away from the rest of the remaining shell. Blower motor hole is bent a little, but can be straightened. Also the right front inner fender, both front frame rails and the radiator support. Right Inner fender has a 2 inch patch at the top rear corner and a little cancer at the front most bolt hole where the fender mounts to it. Both Frame rails are good and straight. Also have the whole roof (notchback), deck lid and all the glass for sale in other threads here on FABO. (left inner fender is not avail - I need it for my ragtop)
firewall/cowl - $200 - still needs cut from the shell
inner fender - sold
front frame rails- $75 each - still need removed
radiator support - $75 - still needs removed
roof - $100 (already removed - cut at the pillars and just below the sail panel seam)
all glass - $25 a piece (clear from a non-a/c notchback car)
trunk lid - $50 (trim and clips NOT included)
Located in Glen Burnie, Md. Will ship most items at your cost. Prefer local pick-up or meet up to 2hrs away for fuel cost on the roof and cowl, although shipping at your cost is not out of the question.
money never showed up for the inner fender, pm not returned for 2 days now.... Inner fender is now avail again - right side only.
edited to say: Latest update - the check is in the mail... sale pending it's arrival.
BUMP> Still have the firewall/cowl, roof, radiator support, all glass, trunk lid,
also have the rear floor section from the front edge of the rear seat to over the rear end.
here is what it left of it >>>>prices dropped - need it all gone.... local pick up or you pay shipping from Glen Burnie, Md
radiator support - $50
roof - $50 (already removed - cut at the pillars and just below the sail panel seam)
all glass - $20 a piece (clear from a 68 non-a/c notchback car)
trunk lid - $40 (trim and clips NOT included) has repairable rust under bottom lip
