Help wanted please (pictures, drawing)
Wheels
B.C.
I am working on my 68 B'Cuda I am building my own patch panels
for my lower quarters and the corners where they join the rear valance
I also will be making trunk drop panels for the inside of the quarters.
If some one has pictures of the lower quarters inside and out where
the quarter meets the drop panels - is there a 90 degree bend at the
bottom of the quarter where it meets the drop panel or is just curved
in to join. and a close up of the wheel well lips near the bottom.
I posted a while back and got the measurements but need more info
to do it nice. Cheers and thanks. I have down loaded pictures
of repop drop panels unfortunately the pics don't have measurements
on them so that would be nice to , just the part that hangs down.
AMD Driver Side Trunk Floor Extension.
The down side (or face) of the trunk extension tapers in toward the body center and is followed by a 1/2" flange that meets the quarter the entire length (#3) until the rear radius. As the radius curves up the flange tapers to 7/8" .
That 1/2" flange ends up being close to or even parallel with the trunk floor.
Make sense??
Some pictures looking from front to rear AMD Driver Side Trunk Floor Extension...
measurements for A,B,C,D, please.
Thanks Dave , really helps a lot. Do you think you could measure that panel for me.
D=7-1/16"
Overall Length is 29-3/8" Length to the angle is 28"
The panel face is bowed out starting about 1/2" in front of the "D" hole. That is where the 7-9/16 comes from measuring over the bow. From the "D" hole back it is basically flat. Should see in the color picture. Looks like they get resized when uploaded.
That is awesome Dave . I really appreciate you taking the time to do that for me.
Thank-you
No kiddin. Good work yall.
