273 cyl head port sizes
4spdragtop
Ontario Parts Unknown
I flipped thru both our 67 and 69 service manuals and cant find sizes for the 273 cyl head intake ports. Its for Dads 67 273.
If you have exhaust port sizes too that would be great, but for now looking for stock.
2bbl, 4bbl and Commando IF there is a difference between the 3.
Thanks
Steve
Steve, I don't believe I have ever seen specs on the port size. The ports are the same between 2 and 4 barrel. The 4 barrel and Charger/Commando engines are one and the same. I'll bet someone here has a set of heads handy and can give you a measurement. tmm
#2658920 {1966 and 1967 } '273' Castings
Intake Port.......... 1.05" Wide x 2.07" Height
Volume............... 124 CC's
Exhaust Port....... 1.14" Wide x 1.59" Height
Volume.............. 61 CC's
#2531984 'X' {1968 thru 1970} '340' Castings
Intake Port.......... 1.16" Wide x 2.27" Height
Volume............... 160 CC's
Exhaust Port........ 1.25" Wide x 1.75" Height
Volume............... 70 CC's
Thanks guys, weird..I kinda expected the factory manual to have these specs. I cant get to the casting #'s as Dads car is in storage about 5 hours away.
The reason I ask is I have a couple of aftermarket 4bbl intakes.
#2843675 {1968 and 1969} '273' Castings
#2843675 {1968 thru 1974} '318' Castings
Intake Port......... 1.05" Wide x 2.07" Height
Volume.............. 125 CC's
Here You Go >
