Proportional valve.
It is both.
Distribution with rear hold off (proportioning) valve.
You can tell by the plug screwed into the end that holds the valve and spring that does the proportioning.
Thanks, I am loosing my mind I sent a member this and he said it is not a prop valve but a distro block.
That pic is just a distribution valve. The pic from E-Bay was a combo valve.
is it a good idea to show your name and address in public view of the net .....jus sayin
