[WANTED] Power steering brackets
Dartsun
Mopar Dude
Springfield Oregon
Hello I'm looking for the brackets for TRW style power steering pump in picture. I'm wanting to use it on my 340 69 dart. Thanks Dustin
You need to be a little more specific as to what front assembly you are running! The 1970 and later aluminum water pump uses different brackets and pulleys than the 69 and earlier cast iron water pump setup, power steering included! Including this information will help narrow your search and help others help you!! Geof
Sorry I'll be using the 69 and earlier cast iron water pump with pump outlet coming out drivers side. Thanks Dustin
