think I got it fixed (the link, not the engine)
Unplug 1 spark plug wire at a time and try it.
had a water pump bearing go bad, had that funky noise , i would take the belts off just to eliminate front motor noise possibilities , good luck, hope its something easy
If the cam sprocket is coming off, the cam will be able to slap the rear cam cover. Put a timing lite on it. If the timing is rock steady, your sprocket is fine. If its jumping around,several degrees or more, keeping time with the noise, Bingo!
What about crankshaft end play?
torque converter not properly installed?
Pull the starter off. Look at the bendix. It has a retaining ring that is notorious for coming loose and when it does, it falls into the ring gear and makes a heck of a noise.......very similar to what you have.
Sounds like a big end bearing failure to me. My 360 had a very similar knock, especially when you back off the throttle. I would take the sump off and check each one, I reckon that's where you will find your problem.
Regards
Anthony
Total bummer ,I feel for ya.
the difference between a "stock" rebuild and a 408 is less then $1000.00 when reconditioning rods, about $1400.00 with new rods
http://www.forabodiesonly.com/mopar/showthread.php?t=320354
on a side note, does anyone know if I can unbolt my dougs headers and leave them connected to the rest of the exhaust when I pull the engine or do they need to come out the same way they went in?
