mY BRAKES SUC....
halifaxhops
It's going to get stupid around here!
Hoppyworld, PA
I need either a vac pump or hydraulic assist brakes (my vac is only 7 in lbs with the 440) Any one use either? New territory for me.
Oh yeah I did add a vac can but only get one more good stop with it.
No way tried it, 440 in a 5k car,(se) disk on the arse. Need a good sucker or an alternative.
Thanks BS, That looks like what I need where do you get them?
You'd have to shop around. I just had that site bookmarked for info purposes. I'm not sure they do Mopar.
Bruce is spot-on. I put the HydraBoost on my Scout with discs all around. Stops that fat pig on a dime. I did put an adjustable prop valve in the rear circuit..
What did you use Rick? I was ready to hire a hooker every time I drove it to keep the vac up.
Rhoades lifters will also help increase your vacuum at idle...
Comp makes a vacume pump you can get it from summit I have one on my 67 barracuda now I have no fear because I have brakes all the time.
I got a setup based off of a GM diesel, put a corvette MC on it, plumbed it.. really east stuff. I bought the stuff off a guys project he lost interest in, pennies on the dollar. All stainless lines too. I'll find out who the mfr of the stuff is. I called them when i installed it and guy was real helpful, even though i didnt buy from him..
Convert to manual brakes. These cars are really so light they don't need power brakes.
Rusty's right on. :thumbup:
My Duster has manual disk brakes, my Challenger has power disk brakes. As soon as I feel like getting into the brake system on the Challenger, that booster will be gone and I'll be running manual. The factory power brakes are lame.
RMS had, last I looked, a hydroboost kit. Have heard of some folks using the parts from diesel pickepmups....
Nice.. Ben Drinkin .. Nice find.. ..
If the brakes are not right, adding a booster isn't the fix.
Unless the cam isn't allowing enough vacuum signal. Then yes, a booster is a fix.
My car is right at the threshold, 13 inches, and my power brakes don't like it. They work, but not as well as they should, I am ditching the booster and going manual.
I have 6" of vacuum in my 70 'Cuda. I had the booster rebuilt and went to Police/Taxi rotors in the front and Dr Diffs econo rear disc kit while restoring the car. The brakes work way better than stock and have excellent power assist.
With the / everything was great that is what I am having a problem grasping. All ines, calipers, booster, master are new and bleed. Even checked the brake rod a few times for adjustment.
Yes, you are correct, I missed the point of the question. I was referring to adding a power booster to a non power car to solve a brake problem. Low vacuum is a problem with a power assist car. Id say it would be easier to just convert to full manual.
