fish340s
Active Member
‘67 Barracuda fastback parts car for sale, at this point I don’t have the time to part it out so would rather sell as is, if it doesn’t sell will probably try & part it out in the next few months as time allows. It has a factory A-body 8 3/4 rear axle with 489 center section & 3:23 gear ratio (open) under it with the driveshaft (and everything else needed to transplant an 8 3/4 into another A-body). Besides the 8 ¾ rear the other good parts are; doors, side glass (clear) & rear window (tinted), core support, right side inner fender and frame rail, left inner fender has some wrinkles and not sure about the condition of the left frame rail, rear frame rails look to be good, useable header panel. Has aluminum 4 barrel Edelbrock Performer intake, Carter TQ carb (crusty & needs rebuild) & aluminum valve covers on 318 & 904 auto of unknown origin & unknown internals, it was not running when I got it and never tried to get it running. Not much remains in the way of exterior trim except for the belt line moldings and a couple of grille pieces. LH inner quarter panel might still be useable. The floorboards are rusty & interior is gone (as in not there). RH lower quarter panel also gone. Fenders are wasted, bumpers might be good for cores? Like I said it’s a parts car not a restoration candidate. Originally was a 273 drum brake bench seat auto on column. $800 cash. I can help with delivery if you’re within 100 miles or so of Fredericksburg, Va., possibly further away for cost of gas & tolls (if any). Pm here. Thanks.
