Break time
draginmopars
Shady Hills, Florida
Finally quit raining on race night
So, took a break from working on the 72 dart.
Took the 70 more door to the track
have been running 6.84 @ 30* timing
Decided to bump the timing to 34*
95*.... track temp 130*
spinning the tires> new 325-50 x 15
let air down more to 16lbs
buddy says still spinning/smoking the right rear/ half track
I say NO Way> spool
car has slowed to 7.13
I thought it was due to the hot outside temp/ track
next pass
smoke pours out of the car, at the end of the track
load up go home
pull plugs... right side # 4 don't look good> oil
pulled the valve cover still can't see anything
next morning, pull the head
at least it wasn't a piston
#6 was also pushing the gasket
Felpro 1008
didn't hurt the head
still gonna make a very light cut to be sure it's flat
Wonder if I should go to a MLS head gasket
comp is 14-1
running E85
Break time is over
Time to pull the other side
also while the heads are off
gonna verify the timing mark is correct on the balancer
while you have the heads off you might want to consider O-rings. mls is the least you should do for your compression ratio. did you use the proper torque value for the lubricant you used.
Hi, Bob,
yes, ARP Studs @ 95lbs, with supplied lube.
engine has 52 passes
I really think I need a timing retard for the launch
is why I set it at 30*
anything more, blows the tires off @ 4500
Calvert shocks helped, it stopped "leap frogin"
need to work on that some more
went from 275-60 to 325-50
but couldn't tell due to this recent issue and the heat
also need to lean it @ 10.74 (gas scale)
get to mid to high 11's
the driver's side head gasket was fine
3 week wait for MLS gaskets, in my bore and thickness
so, went back to 1008 until they come in
Horses are chompin at the bit to get back to the track
LOL
I might change my name to
"Parts Breaker"
rain finally stopped to be able to go racing
First pass felt like spun the tires , engine revved
Second pass,watched tach, engine went to 7, car left slow
got to trailer, stall check>>> 7 grand
time to pull the converter ( was 4500)
While the engine is out for a converter change
gonna put the 340 that is for the other swinger, in
for a few test passes
until I can get the converter back and o-ring the engine
1968 spec engine
268* solid flat tappet
3500 converter
What about cosmetic gaskets?
I may do that
Will have to see
Am going to lightly mill heads and block
see what I need for a gasket (thickness)
also going to retard the cam
to kill some bottom end
I don''t blame the converter,
I have been hard on it
"Leap Froggin"
trying to get the suspension dialed in
got the engines swapped
ready to go to the track
NOT
checked the schedule> track closed> Friday night
LOL
have to wait until Saturday
got 27 runs on the cosmetic gaskets
Ended up using a set I had for another project, but they are .075 thick
the correct ones came in the next day,
after we had finished re installing the engine> figures LOL
now, we are back to playing with timing and shock settings, launch rpm
FWIW. Along time ago, the guy that did my machine work (He does LOTS of Mopar engines.) told me to use studs and go to 120 ft-lbs. on small block Mopar heads. I'm running 12.5. Blew one head gasket, head was slightly warped, cleaned it up, used fel pro gaskets, And haven't had any problems for 30 years.
Thanks for that info
I do use studs in all engine builds
I did go to 100ft lbs.
I just wonder
how much more these old blocks can take before pulling the threads
For this engine, i don't want to go more
due to it was bored with torque plates @ 95 ft lbs.
don't want to dis-sort the bores
Hadn't even thought about that.
In my case, the guy that told me to go to 120 ft-lb was the one who honed it (with plates).
The snow ball got a heart transplant over the Winter
Current engine -pulled out to cut the pistons for more valve clearance, so i can advance the cam more.
put the thinner head gaskets on .040" vs .075" Cosmetic
and a few other items
after 3 years the W-2 stroker is ready
got the headers finished today, hope to fire it up tomorrow
after I finish with some Radiator mods.
also making a converter and rear gear change
since need new rear tires, going to a 315 x 60 et Pro
had to change the Hood due to No carb clearance
Lost its sleeper look.
Getting ready to let these new horses run..lol
Et Pro Tires are on back order until May 19.
Plan "B"> put 275 Et Streets on temporary.
Got the Air pan for the cowl hood completed.
checking everything over
Ready to see what this engine will do.
