rdakota340
Who has got one in use and the results I'm thinking of getting one. They look nice other than the price my set up now is not good in traffic its fine going down the highway !
I run mine (twin fan system) without the fans whenever I'm on the highway and it never tops 185.
They cool so efficiently that I unhooked one of my fans and I have a back up now.
Never gets over 190 and that's idling with AC on and there's a big block in the bay.
Worth every cent.
I went with the derale 2 stage fan controller. It turns one on at one temp, the 2nd at a higher temp.
Thats good news guys got one ? Did you guys cut out for the extra air flow I have a 22'' opening.
Thank you....it's where it eat my dinner.
I had the same problem. I went to a champion 4 core radiator. I had to do a lot of "massaging" to get a larger unit in there. It still ran hot. I went out and bought a wideband O2 sensor and put it in. I was running way lean at part throttle. It was around 18:1-20:1 AF mixture. I adjusted the carb and all of my issues went away.
