Lugnutz
Member
I am looking for a little help from the cam gurus here.
When it comes to aftermarket camshafts, cam lobe over lap and or centerline how much is too much to where it creates issues for power brakes? I would rather not plumb in vacuum canisters or vacuum pumps.
I am planning a 318 engine build for the girlfriends car. Its a 70 Dart, currently a slant 6 and 3 on the tree. She wants a V-8 with a 4-speed, power brakes and it has to have a rumble in the exhaust note at idle. She heard a friends 360 start (manual brakes, dont know what cam) and turned to me with a big smile and said I love that sound.
Years ago, I ran a 318 with 360 (1.88 valves) heads and it had a 270/480 cam in it. I really liked the rumble it had at idle but it was low in vacuum. The car had manual brakes so it wasnt an issue.
The plan is to build a 318, with 302 heads, 2x4 intake/ 500 carbs, A833, probably 3:23 gears and undecided on tire height at this point.
A mid 13 sec car would be plenty fast for her with a little coolness factor when she lifts the engine hood. Fun factor and drivability are more important than max cubic inches or max horsepower. :burnout:
I am undecided on camshafts at this point and I really like the dual pattern cams with more lift/duration on the exhaust side.
What would the cam experts recommend that would cover the rumble requirement at idle and create enough vacuum for power brakes?
