[FOR SALE] SB Headers, Cam, Connecting rods
mshred
The Green Manalishi
Small Block Mopar Hedman a-body headers, 1-5/8 primaries with 3" ball and socket flange collector. Have a few dings for clearance in them, otherwise in great shape. o2 bung already welded on, need a little cleaning and some paint. $150 obo
Small Block Mopar Custom Comp Cam Solid Flat Tappet by IMM engines. Cam was used one season only, changed to a solid roller and no longer need it as I am cleaning out what I have for SB stuff. Cam specs 251/260 duration at .50", 108 LSA, .556int/.558exh lift with a 1.5 rocker...$150 obo
Scat Small Block I Beam Connecting rods. Used only one season behind a mild 360 application 3 seasons ago. Nothing wrong with them, just have no use for them and need to clean out the garage. In like new condition, and still have bearings with them too. $250 firm
All items located in Ontario, Canada. All prices are plus shipping (headers local sale and pickup only). Message me for more info and pictures of the items.
BUMP for new prices! $100 for the headers and $100 for the cam! Message me for pics via email, everything is in GREAT shape, I need this stuff GONE!
Potentially interested in the cam and the headers. Do you know if I can use my stock rockers with that cam, or should I ask Brian at IMM?
rumblefish360, thanks for the reply. By stepping up, are you speaking in terms of strength, or in ratio, or both? If I went with that cam, which is already pretty radical in terms of lift and duration, using 1.6 rockers would put the lift at .593 on the intake side, and .595 on the exhaust. That cam may be a bit much for the street. Could be fun, or it might be too much.
Lift has no impact on durability or streetability, duration and lobe centers are much more important in that regard. I would use an adjustable rocker so that you can accurately setup lash, but I dont think it is a requirement- I've never ran stock rockers with any performance cam so I couldnt tell you, as to me a cam upgrade goes hand in hand with a rocker upgrade, make all the valvetrain up to snuff imo
I definitely wouldn't consider it a radical cam, but it depends on your setup. The headers are local sale and pickup only as I have nothing to ship them with.
Let me know
Thanks for your interest
Headers and rods sold, still have the cam...BUMP
