[FOR SALE] Big block k frame and oil pan
rlcbit
Paducah. KY.
For sale 893 oil pan and k frame for big block a-body 67-69 . $1200 for both + shipping
Is this an actual Dodge manufactured Big Block A Body K Frame? Or a torched, cut, welded, and grinded, A Body K Frame- set up for Schumacher Motor Mounts?
Don't get me wrong- Both are good, in fact both are excellent. Only a few of them are the real deal Mopar Component.
Pardon me if that sounds like I'm coming on to strong, don't mean to sound like an a hole, it's just that I already own one of above items.
I'm more concerned about owning the real deal.
Thank You,
Scotch AKA the paintguy AKA thepaintguyinsanford.
Would you consider just selling the oil pan?
The k-frame and oil pan was on a 1969 GTS 383 dart . Both are stock . I will sell just the pan make me a offer. Thanks
rlcbit...
i'm looking for a 69 a-body k frame that would fit a 440. do you know if there is any difference between a 383 and 440 k frame other than the engine mounts?
could you post some pics of your k frame...
jim coster
pittsburgh, pa
Here is some pics . I do have 440 mounts m code .
There is only one Big Block K-Frame. With the correct mounts any of the big blocks will fit.
To use correct mounts you must also have the correct blocks with the special drilled out bosses. My 2 cents
Here is one of the first 440 mounts in May 67 from Grand Spaulding dodge. The dark one. The three primered ones are factory for m-code a-body's .
More pics of the supposed '67 Grand Spaulding mount??
Are the other 3 original factory or the repo ones Dan did years ago?? (easy to tell)
