[WANTED] Small Bolt Pattern Wheels and Tires
JGC403
Baileyton, TN
I need 4 small bolt pattern wheels and tires. Plans change now I'm moving, I just need them for the move. Need to have tires. Nothing special, just steel wheels. I'm in Eastern TN, near Greeneville.
how far will you be rolling the car? you can use 5 lug late model wheels as rollers they have a metric pattern but its close enough for rollers. I got em off of k cars (5 lug) or some turbo cars avoid interpids or the like theyre similar to Big bolt pattern
how far will you be rolling the car? you can use 5 lug late model wheels as rollers they have a metric pattern but its close enough for rollers. I got em off of k cars (5 lug) or some turbo cars avoid interpids or the like they're similar to the big bolt pattern
that is correct, "K" car wheels 81 - 95 used a 100 mm bolt circle. the 4" bolt circle is 101.4mm. Close enough.
