john-9
just how accurate are the pinion depth checking distances inscribed on aftermarket gears (Chrysler8-3/4 , Ford 9 inch etc.) -- seems with setting the depth using pinion depth setting tools available gear patterns seem to be off a bit -- compared to old school method of shim changes till you get the best gear pattern available.
any have the same experience when setting up gears,
thanks in advance
thanks in advance
