70DusterBob
I recently made a modification that got me 27 hp in third at 2800RPM, which someone told me is x 2.45 for first gear, which is 66 hp. I got a 50 ft lb in torque at 2800RPM also increase in third, so in first that would be 122 ft lbs. What would the engine hp and torque ft lb increases be with those numbers? Is there a way to be able to calculate it? That was a 20% increase in torque and hp for my set up, w/a 360.
I am running 3:55 gears in the rear, but have very tall 15 rubber on 15 in rims. When the speedometer was working, it was reading close to if not perfectly accurate. I assume, since it was born with a 225/904 w/14" rims, that what ever the gearing would be for that set up would be the same as what it in it now. I'm guessing they came with different gearing in the rear, how could I find out what the original gearing was if I needed to, the VIN?
I can get the tire size off the tires, but don't have it handy. 727 trans.
Thanks
Thanks
