Starting my front end rebuild - Homemade tools?
MrJLR
Built, not bought
Menifee, California
I just ordered all my parts - all Moog from Summit....$440.47 - woohoo!
I did get the offset bushings.
I did order the ball joint tool...
But, as for removing and installing upper and lower control arm bushings, I'd like to see some pictures/descriptions of what other members have made for homemade presses!
I'm thinking some all-thread, nuts, big washers, and piping.
I'm sure not going to pay a shop with some pimple faced kid who will bend my control arms all up!
I do have access to a press at work, but I'd like to make something and do it at home if possible
So.......let's see what you guys have made!
Jeff
:coffee2:
Know what check the stores like auto zone and the loaner tools. I know I have gotten a few over the years from them of something I did not want to buy and it is free!
In is the easy part always had problems getting them out.
Yes.....that IS the other issue...!
I guess it'll be a version of the homemade installing press (in reverse so to speak) and HEAT....but not too much!
Believe it of not, I'm REALLY looking forward to this....and I'll do this all day long over working on my wiring! LOL
Jeff
:burnout:
To me the easiest thing I have done is blow the rubber out then chisle the metal shell out. Sounds hard but not to bad really.
A regular one start trying to get the flange going some times they come right out. The air chisle vibrates a bit to much for me. Also try to clean the 40 years of crud off the back and blast it with penetrating oil. 2 out of 5 come out usually easy.
If you have a wire welder and a press the easiest way to get the LCA bushings out is to weld a washer on the front flange then use a press with a 9/16 deep impact socket and short extension to press the sleeve and washer out.
I did the all thread, pipe, washer setup to get my UCA bushings out and one word of advice, use grade 8 stuff, otherwise you start cross threading under pressure
I used some cheapo 5/8" ? all thread. just fit inside of the bushing hole for the uppers.
did throw a little grease on the threads. always ran the poly lower bushings so I just torched the rubber out of the lower sleeve and ran a wire wheel in the inside of the old bushing housing.
