The usual problem that people run into with Mopar vent window/window glass cars is that in order to remove the window glass you have to first remove the divider bar, but to remove the divider bar you have to first remove the window glass! The answer is to remove all the hardware attaching the divider bar; then grab the top of it and pull the top of the divider bar backwards as far as it will go (about halfway back). This will free the window glass so you can get it out of the way by sitting it down in the bottom of the door. Once the glass is lying down inside the door, you can pull the top of the divider bar all the way back, at which point you can remove it from the door. Then you can pull the glass straight out.
