Stop in for a cup of coffee
So you wanted the one that just goes up past the center body line? Where is yours actually damaged? My Duster was mostly just lower rust out below all the body lines except a little near the wheel wells. I just used flat sheet metal and shaped it. It is a lot less work getting the big piece if you need to repair much that crosses body lines. much easier to fill a couple relatively flat weld seems.
i could probably get away with just a lower rear patch but i'd rather have the skin
beautiful ....I might be strange but I actually looking at project cars ....maybe more so than show cars
thats from the day I picked it up, lots has changed since then lol. a lot cut off. I need to get some new pics
Lost power and it is back. literally the last house on the run. Talked to DDaddy, thanks man no more carb parts search!
He didn't say. the full quarters go all the way up to the sail panel of the roof vs the top of the body line. Full quarters also extend to the trunk gutter.
The skins aren't being made anymore.
Really, I could probably patch the front lower of my quarter if I could find a rear lower patch panel
You could always get the full quarter and cut what you need to patch into yours, or just use the full one...
At least SOMETHING is still available and we're not left hanging...
Basically just the headlight harness and get it on the lift to run the wire from the trunk to the front and all the aftermarket crap still to do.
Is that a custom Rear Window Defogger ?? :poke:
no clue why it was taped like that, PO did that.
yeah, I hope i dont need to do that. I'll probably just order from c2c like mike and be done with it. Full quarters are 600 bucks, vs 279.99 for the skin from AMD
Think I will at least pull the intake and see if there is any debris obvious in the runners and ports.
i was wondering the same. I think that image of the full quarter isn't one from a 72-76 dart as the gas filler is on the drviers side of those.
How come the skin doesn't have a ho for the gas fill and the full quarter does??? :wtf:
Try calling tamraz and see if they carry it in Goodmark or other brand.
challenger fenders were listed at $650 at mancini, $550 at tamraz, and when I called them, he hooked me up with a Goodmark fender for $288 out the door - I pick it up. It was good quality and more affordable since they had them in stock and out of stock on AMD at the time...
You get better prices if you call, than you see on their internet sites...
@halifaxhops Hey Ray, I think I figured out the mystery of that rear set up in the Belvedere. I searched the libraries at the Hamtramck registry and found that it was the same set-up used on the large station wagons and A100 vans. 7-1/4 rear with a slant and 15" wheels.
Looks like the patch will more than cover it. One big downside of that is you will see the repair from inside. To me a sheet metal patch was just dandy for the $ difference. :thumbsup:
:mad: :mad: :mad: F*ckin oldest kid just pissed me off.... :mad: :mad: :mad:
I won't go into details, but I caught him doing something behind my back without asking me and then lying about it to my face.... :icon_fU: :icon_fU: :icon_fU:
Im highly considering it. I don't care about from the inside, it won't be visible either way, it'll be covered. ;) top secret plan lol. I just figured since I was doing a full quarter on the drivers side, I'd do it on the passenger side. Looks like AMD does have lower patch panels for a 70 to 71 but not a 72 to 76, Hmmm
10, 9 ,8. Im dreading the daysy kids hit that point. My 2.5 yr old is already causing me to lose hair and sleep with her mischief
Nip it in the bud early, because if you spoil them too much, it's hard to get them back on track later.... :mad:
Hindsight... :BangHead:
