[FOR SALE] Dual quad 340 intake manifold with carbs and new, A body SS headers
Bucky Jones
Georgia
Rating - 0%
0   0   0
Edelbrock intake with 2 edelbrock carbs, linkage, breather and braided fuel lines. Plug and play. Came off of a running 340. $450++ and I will throw in a holly electric fuel pump. Will trade for a stock 68-71 340 exhaust and intake with AVS/Thermoquad for a 4sd. Will also consider 3.23/3.55, 8 3/4 3rd member (1966/67)
I
am interested in, shipping to Wa. 98367 (any pics)... Pm sent
PM sent again...
MIGHT be interested in the intake w/carbs. If you provide pics. Got 340 Hi pro manifolds for trade.
I am first in line, pm sent and conversations started... thanks.
I believe the D64 intakes are a specific fit to the '64-65 273's only, due to the bolt mounting angle on its heads. The Edelbrock D66 dual carb intake would be the one to fit '66 and later LA small-block engines.
Was this manifold remachined for correct fit on a later LA engine?
yes...this is true
I think I can txt you some pics. U have a stock 340 intake and 2 stock exhaust manifolds? What are the casting numbers?
For the last time: Set-up came off a RUNNING 340 engine that I took out of a 67 Barracuda S that I recently purchased to restore to it's original condition with a Commando 273. Intake will only work on my 340. There is no way it will fit on any other Chrysler 340 ever built.
If A=B=C then A does not equal C
