Supercharged 6.4L in a 64 Valiant
Perches and upper 4 link bar brackets fully welded.
I skipped a step here. I ordered my wheels and tires a while back. They came before I ordered the rear end so I could measure accordingly. Weld Racing S77B's. 18" X 7" Front w/225 40 18"s. 18" X 11" Rear w/ 315 40 18"s.
Matching numbers sort of 6.4 in a 64.
If this car does not have a full frame, Do not forget to weld in sub frame connectors or you might get some twists which you don't like.
Plumbing help. Radiator/Transmission line(s) is inverted flare. The "flare" does not seat. The "hex" part bottoms out before the flare seats. Need to go from inverted flare to -6AN.
