Small bolt pattern Disc Brake rotors Bendix
Slantsix64
Los Angeles
going to put some new rotors on my k-h small bolt pattern disc brakes originally off a 1966 dodge dart gt was wondering if Bendix Brakes PRT1054 Brake Rotor would be the correct fit for my application any thoughts or experiences would be greatly welcome thank you.
You can get slotted rotors from brakeperformance.com. They have worked well for me.
No. That doesn't look correct to me, and it says it doesn't fit my 67 Barracuda, which would have the same rotors. It looks like big bolt pattern in the picture. Here is a photo of a rotor I bought for the K-H brakes. Note how close the lug holes are to the center.
BTW this was a great product (from Summit Racing) but is no longer sold.
thanks for the reply hey. i just received the rotors, they look good but ill see how they perform and yup they are small bolt pattern just mated them up to my old 9 inch drum set it. it looks like they are big bolt pattern due to the center diameter but that is where the hub is attached
Update the rotors worked perfectly i can stop now. so the answer to my question is Bendix Brakes PRT1054 Brake Rotor due fit 1966 dodge dart kelsey hayes 4 piston small bolt pattern disc brakes. got both rotors at summit for 50.00 pretty good quality. another thing i like to say the brand Raybestos PGD11 Front Premium Organic Brake Pads due not work with calipers they are a little bigger. they might work with other later years 67-72 kelsey hayes calipers.
