mopowers
From my experience with mine, I still expect you'll find the IFRs too small. You can test your idle circuit by temporarily putting small wires in the idle air bleeds, which will richen your transition circuit. ***Make sure you secure the wire so it doesn't get sucked into the carb*** If it runs better, then you know you need a richer idle circuit.
If it's just off idle that you have your problem, a new power valve probably won't help, nor will a different pump cam (this is only from my experience: your results may vary).
I do think the IFR needs to be larger in order to richen the transition circuit a bit. That would mean the idle mixture screws would need to be tightened as well, right? I'm already only at 3/4 turn out from bottomed out on all four idle mixture screws.
