chad h
Member
So im near completing my 340 what i need to know is what pulleys can i use its a1968 block with jheads every were i look has 70 and up pulleys ill also need info on alternator bracket no air or power steering thank you
I believe if you have power steering you will need a dual groove crankshaft pulley, if no power steering a single groove.So im near completing my 340 what i need to know is what pulleys can i use its a1968 block with jheads every were i look has 70 and up pulleys ill also need info on alternator bracket no air or power steering thank you
First off, what car is it in??? year and model....
Then look at the water pump to see if it's the cast iron or aluminum...
Then we can go from there...
This one is going in a street rod have not purchased water pump yet
