73 dart sport factory fuel and temp gauges not working
Altamont, IL
As the ritle says my fuel and temp gauges do not work on my 73 dart sport. They haven't worked since I have owned the car. I'm guessing the viltage limiter went bad. If that's the case is it likely that it fried my gauges or could I just replace the voltage limiter?
Most of the time the limiter just fails inside and stops supplying voltage and the gauges are fine.
I gave my limiter away to someone who needed one, and they can be gotten online, but you can also make an electronic one for about $1.50
An electronic one will supply a steady 5v instead of the old OE mechanical on/off style and this is one I built and it worked perfect.
It uses a Radio Shack 12v to 5v regulator that I think was about 50 cents.
Check out RTE's site RTE limiter - rte for more info on how these things work and why you might not want the steady 5V. Of course they are trying to sell a more expensive product, but it's more of a direct replacement for the factory limiter.
To get to the limiter im guessing I will need to pull the cluster out or can I just drop the column and get to it while it's in the car?
To pull the OEM and plug another in from underneath the dash can/has been done but... it aint easy or simple as it sounds. Why?... the middle leg of the 3 is the 12 volt contact. There's another male spade poked in there with the limiters spade. So 2 males in one female ( keep your dirty mind to yourself ). That extra male terminal is on a dangly piece of wire coming from a noise suppression capasitor. Although some yahoos, and even some vendors website info might state ,"you don't need that anyway",... to omit/delete it can result in a loose connection. Limiter operation could come and go with bumps in the road. So... try to get it back together correctly from underneath if you want.
A better plan is follow the instructions found in factory service manual to R&R the panel. Clean all contacts, bench test everything, 6 to 8 new light bulbs, fix it all at once and be done with it.
