[Found!] 1970 Dart Swinger floor shift column or collar
Odin
Fairfield, CA
I am converting my Dart 318/904 from column shift to floor shift. I am looking for a replacement floor shift collar for my column or a complete floor shift column. I am also hoping for the ignition light feature since my column does not currently have it.
it is a colum out of a 1970 4 spd car, no shaft included was a manual steering car I am keeping the shaft with the box. 1970 is a year on its own. 1971 and later have a depress to remove key button. I also have your key light and map and defogger switch, Key light can be accessed easy, switches I will have to locate the container. Key light is setting on the roof of a car in the shop. it includes the yellow wire that plugs into the map light harness which would be on a timer. map light harness is not include but I also have them
Great! Will your column accommodate the key light?
Can I easily swap your column to my shaft?
How will that affect steering wheel lock/unlock and key removal?
I do still need the map light switch but not the harness.
I ordered a defogger switch but I’m not sure it will properly connect to the defogger wiring. The wiring from the defogger has a two-spade female coupler. The switch I ordered has three male spades on back.
How much $ for each item?
I have a bare collar from a floor shift car. Has provision for the key in the collar though. Just needs to be cleaned up and painted. The collar on the left in the picture has been sold.
Ken
Edison, NJ
