Ok, we all know that a b block fits an a body better, but with lightweight Pistons a 440 revs as good. So how bad is it to deal with a 440/RB block in an a body? All most 451's are anyway is a 440 built in a smaller box with a really short piston...
these days, not bad at all. Schumacher mounts make things fit nicely. TTI and Schumaucher headers both fit well under chassis. May have to use an offset bracket for the master cylinder and do the blower motor mod for added valve clearance.Ok, we all know that a b block fits an a body better, but with lightweight Pistons a 440 revs as good. So how bad is it to deal with a 440/RB block in an a body? All most 451's are anyway is a 440 built in a smaller box with a really short piston...
All true, unless u use raised port victor type heads. tightens everything up, w/ "no" room for any blower motor at all, in a 68 fastback. Hotrod heater under the dash will get u by tho. No. 7 plug is directly in line w/ steering column, and close !these days, not bad at all. Schumacher mounts make things fit nicely. TTI and Schumaucher headers both fit well under chassis. May have to use an offset bracket for the master cylinder and do the blower motor mod for added valve clearance.
under a flat hood? it'll be tight but they do sell a drop base air cleaner that'll work and clear.I'm gonna use aluminum heads and a Holley street Dom 440 intake. I hope it'll fit.
So, your calling him a lier then now are we?!?!photos or it didnt happen!!!!!!!!!!!!
Huh?MODERATOR//////////////////////.>
Good idea even with manual brakes? I'm older now. Gotta have ac. Figured like classic air but open to suggestion. Thanks.That offset master kit is well worth using. It gives you more room and is cheap and easy to install.
Did you use the Schumacher headers or? Probably researching this to death. I only want to spend the money once. That's why I'm picking you alls brains... Thanks for all the advice!Have one in mine, I am the shorter blower motor guy also. No biggie for brakes use a 9' booster kit, hood clearance is ok with a low rise intake, I have a Torker II, one thing I will do when it comes out again is drill two holes in the passenger fenderwell to get to the center spark plugs though, they suck changing.
