and probably the worse place to skimp on if your looking for good performance.
You feeling OK Tony... PTC???
I have used a few Hughes converters and they seem to work pretty well.
You're going to spend about $500 on a good converter.
Adam that link was for a 727, that won't work for a 904 will it??
X2...Yeah, what's the dirt on PTC converters? I may buy one soon.
Anyone thought of taking their convertor to a local re-builder to have one built to specs...We got a re builder here that does the Austin area...
Surely someone local to you all rebuilds them,call your local transmission shop and ask who they use.
Martin
Who is the Austin area rebuilder?Anyone thought of taking their convertor to a local re-builder to have one built to specs...We got a re builder here that does the Austin area...
Martin
Who is the Austin area rebuilder? Thanks!Anyone thought of taking their convertor to a local re-builder to have one built to specs...We got a re builder here that does the Austin area...
Martin
As it's been previously mentioned, define affordable, and do you need a 2800 stall? As I've said before, I don't care whose converter you end up with, get the one that is suited for YOUR CAR. Just because a converter works properly in another application does not mean it will work in your case. Take the advise of guys here on the board and contact the various builders they recommend. They will have a spec sheet on their website that you need to fill in "HONESTLY" and they'll build you the one that will work in your car. B.S. them about what you've done to the engine, rear axle ratio, tire size etc., and no matter who builds it, it won't do what you want. Ask about warranty, ask about re-stalling it should there be an issue. If you let price be your only guide, you'll soon find out that you get exactly what you paid for, and I know this from seeing manyWhere can I find an affordable 2800+ torque converter for a 904?
