??? What's the correct fuse for the instruments or what's the correct location for the instrument cluster fuse???What is the correct fuse for the instrument location??? Thanks a bunch..
Sorry, I can read the location ok, just not the correct fuse. Thanks??? What's the correct fuse for the instruments or what's the correct location for the instrument cluster fuse???
I found a picture of the fuse box. It should be marked next to the fuse cavity. 2 or 3 amp. No larger than 5 amp I would say.
Found it! AGC4 http://www.mymopar.com/downloads/61to72_Mopar_Fuse_Guide.pdfThank you very much, it is not in the owners manual, and I didn't find it in the shop manual either. It is supposed to marked on the fuse box like the rest, it is just not visible. I did find a picture of the box on the internet, it is 2 amps. Thanks so much for your help..
