65 Barracuda A833 shift levers.
circlepilot
El Dorado, Arkansas
I'm converting my 65, 273 Barracuda from a 3 speed column to a 4 speed. I'm using a A833 out of a 65 Dart. I have the complete drive train, Hurst competition plus shifter (10-4-K-1) clutch, bell housing etc. I don't have the following: Shift levers and shift rods. I believe I have located rods, but would like to know the "numbers" for the applicable shift levers.
Norm
I am out right now and If you don’t have your answer by the time we get back, I will look on the trans from the 65 Barracuda i’m Parting out.
Here are the shift rods and levers out of my 65 833. I could not find any numbers on the levers- 2 of them - I think the 1/2 and reverse levers are the straights ones based on the rods and the offset lever/short rod i’m Guessing is for the 3/4.
Hope this helps. I haven’t looked but think you can buy the rods and levers at Brewers.
The reverse is the odd shaped one that goes under the frame the other two are the forward gears and go over the frame in the tunnel
View attachment 1715121760 View attachment 1715121761
How much for the rods & levers ?
I'm still looking for the rods, I found a set of levers and have them ready to install, but cannot find any rods. I've contemplated fabricating some if I had a set to duplicate from, or even some drawings. (tracings) I have the resources to heat treat the material. Anyway if you have a lead on a set of rods...let me know.
Norm
I found hurst shifter site. they have rods and arms. probably have to figure which rod to buy. hurst shifter rebuild, replacement and service parts. probably measure what you need, then ask for a rod close to that.
