Stall ??
273
Ontario
I got a stall questions. Say you have a mild 5.9 Magnum the 300hp create motor. With 3.91 gears and 27" tires.
Now I know the engine doesn't need a over stock stall speed. But wouldn't a small over stock stall still improve performace / e.t. ?
Probably in the 2200-2800 rpm range ?
sure. popping the clutch at 2800 RPM is going to be faster than 1850 RPM. ...
