I've torn apart and repaired/overhauled engines but never done a "performance" build. I have a 5.9 magnum, the block and crank are stripped and ready to go to the machine shop next week. I have a set of new KB 107 pistons. The block will get bored .030 for the pistons. Crank looks great but ill have it checked and polished. I'm reusing the stock rods. I purchased a set of new Hughes 2.02 EQ heads last weekend, and will reuse my magnum air gap intake. Will replace the stock 318 727 converter with something that suites the engine build. I have 3.55 gears and don't plan on changing them.
So, I've been looking at cams and reading about how to choose one and what all the numbers mean. It's all pretty complicated concerning compression ratios and such. Plus the magnums 1.6 rockers add a bit of hassle to it since most of comps numbers are based on a 1.5 ratio. The Comp XR274 was what I was initially looking at them decided it was probably too much. The XR268 seems good. BUT then I realized the 1.5 vs 1.6 rocker difference. Hughes recommends .540 or less lift with the heads/springs I have.
I'm hoping somebody here has built an engine using the same combo and has a tried and true cam choice.
