help with wilwood emergency brake to OEM cable
roylerumble
Edmonton, Alberta, Can
Does anyone have any experience with the Lokar or Wilwood emergency cable kit? I need to mate it to the factory brake cable at the bracket mounted to the drivers side floor (69 valiant). Apparently you can drill the brass block it came with to accept the factory cable end? Does anyone have any pictures of the way they routed the lines from the back discs? Worth adding I installed the RMS street lynx.
below is a pic of the kit I purchased.
