[SOLD] 67 Barracuda power steering
RAT ROD AL
MOPAR ARCHAEOLOGIST - one parts hoard at a time!
Robbinsville, North Carolina
$75 plus shipping from 33956. Includes also center link, tie rod assy, and idler from a slant
six car
Seller says from 67 model. 67 idler arm ( not shown ) is 1 year only. The rest of it would work through 72 model. If changing from manual steering you would still need the shorter steering shaft, a crank pulley, and a belt.
Everything work, any leaks, or do you know?
It all worked on the car, about 6 months ago. I do not have the steering shaft any more. I do have the crank pulley and mounting bracket to the engine block. I've added a couple pics to the listing to show more of the parts. One of the tie rod ends I had to cut off the stud.
