Slantsix64
Just dropped in a 8 3/4 into my abody 67 barracuda how much do i have to cut the driveshaft down? its a automatic a904 8 3/4. Thanks in advance!
i have one i will tell you how long tomorrowJust dropped in a 8 3/4 into my abody 67 barracuda how much do i have to cut the driveshaft down? its a automatic a904 8 3/4. Thanks in advance!
Cool Thank you! i just measured my current one 51.60 original 7.25/904. i seen that i should be at 49.60 with a 8 3/4 so a 2 inch cut to shorten. ill wait to see what you come up with to be surei have one i will tell you how long tomorrow
from center of cap to center of cap 52 1/2
thats with a 8 3/4? i have center of cap to center 51.60 7 1/4from center of cap to center of cap 52 1/2
my yoke part number is 2530892 is that helps.If you are doing it yourself, have at it. If you are paying to get it done... MEASURE!
The problem with looking in the "books" is yokes have variations. The shaft should be the same length for ALL 108" wb, 904/8.75 cars. Yet, there are many different lengths.
Here's a list from moparts.
http://board.moparts.org/ubbthreads/upload2/4563759-PartNoDriveshafts.pdf
I'll just measure it but if the 8 3/4 is 2inchs and 1/4 yoke is longer than the 7 1/4 regardless of wheel base Dodge or Plymouth that should be 2 1/4 minimum cut or exact. But as crackedback suggested I'll just measure it up to be safe.on my 67 dart with 904 and 7 1/4, the slip yoke is exposed about 1 3/4 to 2 inches (saggy springs, 8" ground clearance)
I don't know how long the slip yoke is or how far it can go in or can come out.
